Help Clutch Issues....
Discussion in 'Engine/Drivetrain' started by gilpet79, Jan 24, 2011.
  1. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    First off I have a 92 reg cab with a 22re...
    While driving my truck the other day I kept feeling the pedal lose pressure when I held the clutch pedal in. The engagement of the pedal is very close to the floor but only does it when i hold the pedal in and try to start from a stop.
    I have already replaced the Slave Cylinder and the Master was replaced about 10,000 miles ago.
    Used a flush machine when i did the slave to make sure all air was out before I did a pressure bleed.
    Tomorrow i'm going to adjust the push rod on the master to make sure that isn't the problem.
    So my question is am I looking at a new clutch/bearing assembly or is there something i'm missing?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    how many miles are on the clutch? maybe the master or slave failed ( ive had that happen before on new parts ) if the rod was not setup right it would be horrible from the minute you installed it, not 10,000 miles later later...
  3. Nook
    Nook Addict
    oregon
    I would bet you have a leak somewhere as the pressure plate or throwout bearing has no means of having a pressure loss, only the clutch master or slave can apply any hydraulic pressure, and if its leaking the pressure plate spring pressure will push back at your foot pressure and the fluid is going somewhere, does that make sense :D
  4. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    yea i did a little more looking tonight and found i have a bad seal on my master, Also I looked through my trucks paperwork and found that the master in the car was a remaned napa part
    So the good news is I will have all new hydraulics for my clutch!
