HELP!- (changing guides/tensioner)
Discussion in 'Maintenance/Repair' started by OGtoy, Aug 22, 2008.
  1. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    so my timing chain is rattling. i have about 152k miles on my truck. i have heard multiple things of what to do. 1. get a new timing chain kit and change the whole chain set up, 2. change the oil pump, 3. Change the guides and the tensioner.
    so far i like 3 the best...
    i was wondering if anyone had info on how much it would cost to buy the parts (guides/tensioner) and if anyone had a write up or a link to something that will help me change these things
    if you have any ideas or input please share! thank you!
  2. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    I changed everything!! While your there you might as well.
    Got the whole front end kit from http://www.engnbldr.com/, very good price with a very good guarantee!!!
    I was dumb and put in the bottom sprocket backwards and broke it, e-mailed Ted, the owner, and sent a new one out right away, no questions.
    Pretty easy and straight forward what you have to do.
    There are links out there explaining step by step, just Google it....
    "Timing chain replacement on a 22re"
  3. fourwd1
    fourwd1 Member
    central MD
    84 4Runner rock crawler
    Always replace the entire TC assy, and while you have everythig torn apart replace the oil pump and water pump too. Even the belts.
    No need to replace the TC cover unless the chain has started wearing a hole thru the side.
  4. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    dammm changing the TC assembly is gonna beee a bitchhhhhhh
  5. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    No it isn't, just take your time!!!
  6. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    haha it sucks cause i start this next semester soon.... and the summer is coming to an end... dont have much time.
  7. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
    All you have to do is remove the radiator, fan, drain the coolant, pull off the timing cover, and wala! Repair, clean the front of the engine, drain oil, reinstall parts, and top-off fluids and drive away happy... Unless you cant tell the difference between a piston or a girls titty, you should be fine! Just take your time, read the dirrections, and double check your work.
  8. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    i think the REPAIR part is gonna take the longest... not worried about everything else...
