Hate Cali smog
Discussion in 'Off Topic' started by yota4life, Jan 29, 2011.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Hopefully she passes. Last time she did flyig colors this time an old guy searched everything an found a missing sensor but luckily I left an found a young guy. Wish me luck
  2. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    good luck. i need to smog mine too.
  3. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I hate this **** it sux just a huge inconvience to us all
  4. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    One reason why I will never move there.
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Truck passed tho I just want to move to the county over they have no smog
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    kool...lucky day!! haha
    i have a truck i need to get smogged before the end of the month too....:runaway:
  7. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya mine had til the 31st but I got it paid yesterday an smogged today so Monday I'm gonna get my sticker
  8. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Every place is gonna have smog sooner or later, it just depends on how strict they are. We have it here, just not nearly as strict. :D
  9. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    The thing that bothers me is all the laws around emissions are simply about control. If they REALLY cared about clean air the smog test would be simple. Enter the vehicle year into the computer, stick the sniff tester up it's tail pipe while it's on the dyno and that's it. Who cares if you have a 99 GM 8.1 in a 88 hyundai if it can pass the emission specs for an 88 hyundai what's the problem? The air coming out of the pipe is what should matter and in the end it is what makes or breaks the air quality so leave it at that.
  10. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    ^ I got a smog shop to run my old Toyota with my Weber on it just to have a comparison. They just canceled the test half way through after reading at the tail pipe, then I went home and put my stock carb on and came back for the actual test. My truck ran like 60% cleaner (if I remember right) with the Weber carb.
    I don't mind smogging my Audi though, AWD means no dyno. They just run the sniffer at 2 RPMs. No load on the motor means it runs super clean.
  11. TheLoLux
    Simi Valley, CA
    ^^^^ time to do the AWD YOTA now
  12. Twisted Minis
    Poor Cal
    1980 Toyota
    I just need to find the right Audi transaxle and I can build a V8 AWD Yota. Lol.
  13. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Tht would be crazy as hell. But smog is so crazy they make you do an extra test now if your vehicle is beyond a 95 which is an extra 10$
  14. White Trash
    Eastern WA
    You can use a G58 with its chain drive front output. It uses a differential inside so it can be ran in 4 high at any time. You can use a A340F with it's t case if you want an auto. It's t case is light years ahead of the turd case behind an A340H. I've seriously thought about doing an AWD road truck like a GMC syclone. :D
  15. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Did the same thing in a '66 Mustang I had. Came in with the 2V and the smog crap on it, loping idle and everything (timing at TDC! 0 degrees!). Guy knew me so said to put it back the way I ran it and he would check the results... I ran an Edelbrock 1406 with a K&N air filer... ran over 1/2 less emissions coming out.
    In WA it doesn't matter what is under the hood, as long as it has the Cat if it's needed and runs clean enough, if it's a 20 year old and newer. If it's clean it passes. No other BS. Much more fair.
    Never had an issue here. One of the many reasons I'll never (out of choice) move back to California.
  16. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    It used to be 20 years then no smog after tht I think or 25 something along those lines but now they changed it to pre 75? But if your truck or car is "born" after a certain date in 75 then you still have to smog it
