got no spark
Discussion in 'Engine/Drivetrain' started by naputir, Jul 17, 2011.
  1. naputir
    naputir Member
    guam ft stewert ga
    1994 regular cab
    sup guys got a question i was drining down the road and my truck died on me so wen i brought it home pull the spark plug off an i got no spark could it be my coil pack that went out thank alot
  2. jetas
    Check the wire goin from the coil to the dizzy. If theres spark there then check ur wires. If there aint, check ur grounds.
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    coil
    No spark in all of them? Check the fuse for the coil/ignitor. Pull the wire from your coil and crank the truck you should see it sparking out the top of it on the coil.
  4. naputir
    naputir Member
    guam ft stewert ga
    1994 regular cab
    kay so i ound dat there was copper wire in the distributor dont know were dat came out but i bought a new distributor hopeully dats da problem
  5. TRfknD
    TRfknD Veteran
    The Woodlands, TX via (Guahan)
    96 Taco / 05 Tundra
    Chelu it is the distributor. Just replace and u will be good to go. Don't know why but this is the third distributor I know that this has happened to.
  6. naputir
    naputir Member
    guam ft stewert ga
    1994 regular cab
    thanx chelu for the help when i get out of the field ill install it
