gonna sound stupid...help with radio install
Discussion in 'Interior/Electronics' started by 93V6yota, Mar 27, 2009.
  1. 93V6yota
    93V6yota Member
    memphis tn
    93 xcab black with 3.0 V6
    anyways in my taco it was easy...but this truck is a lil different...how do i pull it apart to get the radio out and put the new one in?
  2. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    to get to the center stere section you have to drop the dash on both sides, its not hard, a 10mm and a #2 philips and you pull down the dash on driver side then its the same on passenger side then u can get to the middle seciton, dont forget to pull the HAVC controlls and dash trim with clock if you have the clock out. there is one screw behind them that needs to be removed. then you can pull it out.
    its not hard at all.
  3. 93V6yota
    93V6yota Member
    memphis tn
    haha thanks dude
  4. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    also, there are 3 at the top when you open the glove box
