Gm 3 wire alternator swap help
Discussion in 'Engine/Drivetrain' started by BILLYDEAN, Jul 2, 2013.
  1. BILLYDEAN
    BILLYDEAN Newbie
    I'm swapping to gm 3 wire in my 82 so I can delete the stock volt reg
    I need to know what to do with the 3 power wire coming out of the volt reg these big white wire big yellow wire and small red wire send power to lights an stuff rite?
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I run a 3 wire GM12SI ,billet cased ,100 amps @ idle/150 above, from Quality Power
    High Output Alternators & High Torque Starters 909-794-1600
    I got a plug from them that goes straight from the stock Toyota plug to the alternator.:cool:
  3. BILLYDEAN
    BILLYDEAN Newbie
    Sweet. Could you post a pic of what wires go to what on that plug? I'll just make my own so I don't have to wait on more parts !
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Be a bit hard to get that in a photo!:cool:
  5. junktown5852
    junktown5852 Newbie
    colorado
    81 hilux
    I sold my Toyota about 6 months ago, but from what I remember I only used the two wires from the harness and one from the alt To the battery...on the 12si harness terminal 2 goes to the charge/battery wire, (should be fat white.) Terminal 1 goes to batt. Indicator light/ ignition. Make sure you run a good size cable from alternator back battery terminal to the positive battery post. Or you can just loop terminal 2 wire to the back post with battery cable. If you do that you'll have to hit like 1200 rpm before it starts charging. Hopefully that helps. I know Toyota liked to change up voltage regulators a lot so wire colors could be different. But fat white usually stayed the same.
  6. junktown5852
    junktown5852 Newbie
    colorado
    81 hilux
    And the rest of my wires I just cut out and taped up in the harness. I don't recommend that. That pigtail harness mentioned above sounds pretty awesome. I'd go for that.
