gas tank cover???
Discussion in '1989-1995 Build-Up/Project Threads' started by white93turbotruck, Jan 30, 2010.
  1. white93turbotruck
    white93turbotruck Enthusiast
    my gas tank cover is loose.everytime i drive it i have to push it back.it has a door lock on it too.can anybody tell me what's wrong so i can fix it???are toyota's prone to having this happen???it's a 1993 toyota 2wd standard cab too.any help would be great.
    thanks
  2. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    try bending the tab inside so that it closes tighter when you lock it.
  3. white93turbotruck
    i'll try that thanks!!!
  4. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    If the cover sits too far in, check to see if the little rubber bump stops fell off. Mine were missing when I got my truck and after putting some in and bending the metal tab for the lock, it works like a champ... no rattling and the cover sits flush with the rest of the body:waytogo:
  5. white93turbotruck
    i'll look at that how much are rubber tabs???are they very expensive????
  6. planemos
    planemos Toyotaholic
    British Columbia
    why don't you run a self tapping screw through a peice of bicycle tire. Or glue a chunk of rubber in there. I'm just saying it could be done for free.
  7. MacRib
    MacRib Enthusiast
    San Diego
    I picked up the rubber bump stops at a wrecking yard, they came off of a Suzuki Sidekick. I think they were like $1. Anything like that will work.
  8. white93turbotruck
    i found the probblem.i'm missing the bottom screw that holds the lock down.has anybody else had this probblem???
  9. macawilial
    macawilial Veteran
    Born and raised in San Diego
    Bottom screw?
    Doesn't sound original. Our truck's come stock with the lock held in by a giant "C" clip. Are you talking about the hinge?:shrug:
  10. white93turbotruck
    i think so and i didn't see a c lamp in there either.
