G code rear end LSD options
Discussion in 'Engine/Drivetrain' started by daruma, Feb 6, 2015.
  1. daruma
    daruma Member
    Hey guys,
    Found out my hilux has a G code rear end (I Guess they all do?) and an open diff. I'd like to put in a LSD, as well as shorter gears.
    What cars have an LSD that would drop right in?
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Easy solution is to switch to a V6 diff out of a 4x4 that'll give you at least 4.10's and put an mkII supra limited slip in it.
  3. daruma
    daruma Member
    currently have a 4.11. As crazy as this may sound, looking for a shorter final, as the 18rg redlines at 7000 rpms, and feels too tall.
  4. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    I wish my Hilux had an 18RG! I guess it's getting a beams in the near-ish future.
    Erwin Merida likes this.
  5. White Trash
    Eastern WA
    If you want lower than that the only factory gears are found in 4 runners from 89-95. V6 automatic had 4.56's and V6 auto with factory alloy wheels and spare tire carrier had 4.88's.
    I'm currently running 4.56's in my 89 with a W58 and 265/50/12's and it's a great combo. :D
  6. daruma
    daruma Member
    NICE! BEAMS is awesome. Almost put one in a celica
  7. daruma
    daruma Member
  8. White Trash
    Eastern WA
    If you use a factory V6 3rd you won't need conversion bearings to use a supra LSD.
  9. daruma
    daruma Member
    so get a G code rear end from a v6 engined car, and the supra diff just plugs & play
    or use my 4 cyl G Code rear end and use conversion bearings.
    Is that right?
  10. White Trash
    Eastern WA
    ALL 4runner and 4x4 pickups have 8" or what is known as G code in 2 the wheel drive world.
    But yes, g code 2 wheel drive or 4 cylinder 4 wheel drive will need the bearings. V6 will accept the diff directly.
  11. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    7.5 = mk2 supra 8 =mk3 supra
  12. justaguy
    justaguy Member
    75 hilux, 84 xtra cab, 86 1 ton, 87 xtra cab 4x4
  13. White Trash
    Eastern WA
    Damn yea you're absolutely correct it's mkIII. I was too caught up watching KOH yesterday to realize my error. At least it was caught before parts were sourced.
  14. daruma
    daruma Member
    King of the hill?
  15. White Trash
    Eastern WA
  16. cosbysweater
    cosbysweater Member
    Monterey killafornia
    going to be doing this swap soon, does anyone know what the 74 hilux rear end gearing was stock?
  17. jetas
    Probably 4.11s. Thats whats in my 72
  18. cosbysweater
    cosbysweater Member
    just pulled a 93 v6 5speed 3rd member today for the car, so if im reading this properly a mk2 supra rear end will drop in?
  19. daruma
    daruma Member
    You can figure it out by checking the code of the diff:
    Toyota Vehicle Identification Number
  20. cosbysweater
    cosbysweater Member
    of course the vin plate is completely faded on the car lol, well i got the 4runner center section and i found a mk2 at the yard with a lsd in it so i need to pull the diff, i will pull apart the 3rd member tomorrow at work, i was lucky enough to find a 4 runner that had recently had a new ring and pinion installed within a few thousand miles, i figure the truck had a catastrophic engine failure, it was a v6 after all.
