Fuel injectors
Discussion in 'Engine/Drivetrain' started by patrickgraven, Apr 5, 2012.
  1. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    So my engine shop told me to have my injectors cleaned or replaced. I found a set of 4hole bosch injectors on ebay. They are 220cc and suposedly increase mpg. Is it worth it or should I have my stock ones cleaned.
  2. patrickgraven
    Corona CA
  3. knucklehead
    knucklehead Enthusiast
    Mount Pleasant, Tennessee
    Those will work, it's only 25cc more than the stock injectors. It's going in the 93 right.
  4. patrickgraven
    Corona CA
    yes they are.
  5. knucklehead
    Those will work, you can also use mazda Denso 195500-2180's they are a plug and play injector and are 254cc per minute, but are probably too much fuel for a stock engine. You can have your injectors cleaned for $80 shipped. I have a few sets of stock 195's ready to go. If you go up in injector sizing you will loose mileage, larger cc per minute at the same fuel pressure is more fuel.
