i am starting to bag my 94 this weekend, and i was able to get 4 brand new 2600s from my friend, we looked at the front and donbt think there is a way to put a 2600 up front. has anyone ever seen a 2600 up front and if so do u have pics of it and give me some pointers on doing it. im running stock control arms and spindles. also, what bag size would fit?
man i dont see that working for you.. you might can cup the frame alot. i think the only way would be a cantilever setup or bags above the arms
You might be able to if you notch into the frame where the bag would sit just for clearance. But I don't see a 2600 up front
i got slam specialties re-7s on the front on my 83.i dont know if thats same size or not but i had to cut a lot of crap out to get them to fit but they fit. im almost done doin the passenger side then i gotta go back and cap everything. i also had to offset the bag on the lower control arm so the steering stuff wouldnt rub it. its a lot of work but itll ride better and i get a little more lift than i would using a re-5 or re-6 but here are a few pics of mine....to see it laid out, check out my signture pic from this angle, it doesnt look like it needs that much clearance, but trust me, it does, esp when its deflated, it also doesnt rub anything, just comes close, lol and heres how much lift i get in the front. ill get a little bit more once my control arms get back, the stock ones hit my upper bag mount
heres the MT article http://www.minitruckinweb.com/tech/chassis/0702mt_toyota_truck_front_air_bags/index.html
That article didn't go into how to notch the frame though. Cando's project Anti-Hack pics cover this issue... http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=323742733&albumId=769049 Very detailed pics....
most toy guys run the 2500, but with enough cutting you can fit a 2600. i agree with litneon about using the anti-hack truck pics. the minitruckin article is way more involved than what they showed in the article.
