Extension hosing seal
Discussion in 'Engine/Drivetrain' started by Yota239, Aug 15, 2011.
  1. Yota239
    Yota239 Newbie
    Naples
    My 92 5 sped is leaking I replaced the seal but it started leaking againg did I miss somthing cause this isn't the frist one i have to do can any one help
  2. Blasito
    Blasito Enthusiast
    Plainfield, NJ
    1983 2wd SR5 22R 5spd(man) - Chopped '84 Honda V30
    idk man is it seated properly? when i pulled my trans out, it will leak if the shaft isnt in. The seal seals on the shaft that goes into the housing itself, without the shaft in, it pisses it all out
  3. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Could be the trans is over-full or the driveshaft sealing surface is damaged. those are most common anyway.
