eradic idle?
Discussion in 'Engine/Drivetrain' started by 86extTURBO, Aug 12, 2011.
  1. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    So my turbo truck has become my daily driver and im starting to notice problems with, i dont know if they where there before or they are new. But everytime i get of the freeway from work (30-40 miles) when im stopped at a stoplight the idle starts rising and falling back to place and then dropping and almost cutting out, What could this be caused by?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    idle control valve is sticking, when you are driving to work its closed cause the throttle is open, then when you stop at the end of the freeway or whatever its sticking and making the idle all crazy, you can try spraying wd40 in the iac holes in the opening of the throttle to clean it out, but more then likley you will need a new valve.
  3. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    can you show me a picture where that piece is?
  4. Nook
    Nook Addict
    oregon
    The up/down idle can also be caused by the idle speed being too high, normally when stopped with your foot on the brake the idle will surge up and down, remove foot from the brake and it quits, if so adjust the idle speed down.
  5. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    i tried that nook, but my truck had the eradict idle today when it was cold but it was fine on the way back from work it was fine except for a few hiccups
