Engine dies at stop after a short drive
Discussion in 'Engine/Drivetrain' started by NickAyala25, Aug 2, 2018.
  1. NickAyala25
    NickAyala25 Newbie
    Guam
    1991 Toyota pickup single cab
    So my 22re likes to dies when I come to a stop after I take it for a small drive.
    It was misfiring at idle and then it would die. So I checked the spark plugs and I had a bad#2 plug. I replaced all of them. I also cleaned the throttle. This fixed the misfiring at idle.
    The compression check read 110, 110, 105, and 100.
    Now after taking it on a 15 mile drive when I come to stop it idles low and then dies.
    HELP PLEASE.
  2. Clay
    Clay Member
    Ohio
    93 Pickup
    Does it always immediately start back up? Maybe check the voltages while the engine is running? those compression numbers seem pretty low
  3. NickAyala25
    NickAyala25 Newbie
    Guam
    Yes it will immediately start back up but it will immediately die again if I don't feather the gas pedal.
    On a cold start there seems to be no issues. But after it drives for about 15 miles and come to a stop it will die.
    Also, here is an update, I have an exhaust leak where the down pipe meets the exhaust pipe.
  4. Clay
    Clay Member
    Ohio
    93 Pickup
    If it were me I would run a multimeter and see what the voltages are and maybe see if they are dropping right as it dies (meaning alternator probably). Maybe swap the ignition coil with a new or used one to check that? could be a drop of fuel pressure as well. or a vacuum leak. I wouldn't be worried about the exhaust leak. only one O2 sensor on these trucks and it only manages air/fuel ratio. not the extent of killing the engine though.
  5. jetas
    Could be the TPS
  6. jjmartinez1987
    jjmartinez1987 Member
    Glendale, AZ
    1995 Pickup
    I think you have low compression should be between 142psi -171psi with no more than 14psi variance between all four. BUT if you can get it going by giving it throttle I would try increasing the idle on the throttle body via the adjustment screw maybe you can get a consistent idle but at a higher rpm than usual.
  7. Lee Gin
    Lee Gin Newbie
    Check valve clearance check timing then adjust carb idle.
