Engine Bay Paint Reccomendations
Discussion in 'Exterior/Body' started by Justin Danger, Jan 19, 2021.
  1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Hi all,
    I'm about to start sanding down and prepping my engine bay for a fresh coat of paint. I was wondering if anyone had suggestions on any particular paint best for this area.
  2. jetas
    As long as its gloss you'll be fine. No need for high temp or any other shit.
    i sprayed mine with dollar cans from home depot. Prep was wiping it down with a degreaser, and its been holding up fine for 3-4 years now
  3. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Honestly, I've always used rustoleum primer/base coat.. the sand able primer is is ok, easy to correct and works! This time around I'm using VHT. I'll also be using their high heat enamel for the engine. Jetas is right no need for high heat paint on the bay, unless you got a turbo Mani/down pipe close by.. then I'd hit the fire wall. Just my 2 cent.
  4. Erwin Merida
    Did I mention all rattle can!
