does anyone have an ecu diagram my next mod is gonna be a boost application but im gonna be buying a megasquirt system for this and i am wanting to make an adapter for it the diy ecu is way to much to spend on somthing that you might mess up assembling ima buy the complete ecu for only 100 more with better stuff to work with MegaSquirt-III EMS System - SMD PCB3.57 - Assembled Unit with black case DIYAutoTune.com
period period period. USE A PERIOD now and then! That way everyone isn't too tired from trying to read your 5 line long run-on sentence to get what you need. Also, what year, engine, and drivetrain?
Ha Ha! What you need is a Chilton's manual. It contains all the schematics you are looking for. There are only a hand full of wires you'll need to find, and you'll have to modify it to work with the Toyota VAST ignition. Read up on MegaSquirt's forum...
no, you don't need a chiltons. they're junk. the wiring diagrams are 1 for all non-carbed trucks that says "typical", "blah de blah similar", and other such garbage. you have a PM BTW
