DTK Stout
Discussion in 'Pre-1975 Build-Up/Project Threads' started by DTKStout, Feb 13, 2012.
  1. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    Started working on the stout again. I sold the first frame I built for it and started another one. I changed my mind on a couple of things and needed to change around a few dimensioins. Here are some pics of the progress.
  2. goingnowherefast
    goingnowherefast Enthusiast
    Haddam CT
    1965 Stout
    thats bad ass man.you do some nice ,clean work.:bowdown:
  3. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    getting some measurements for the front suspension.
  4. Enemy of the State
    Enemy of the State Enthusiast
    1985 xtra cab
    I love stouts! This will be a sick truck when its finished. What size rims and tires are you going to use? Keep up the great work!
  5. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    WOW nice and clean work you have done. Cant wait for more pics.
  6. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Clean an simple I like it
  7. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    I set the suspension up to lay out on 20"s. All of the tubing, suspension, fuel cell, air tanks, etc. are designed to fit under the stock bedfloor (except for the notch, wheels, and driveline of course). As far as plans for the build, I am building as I go. I have a few mods that are for sure. I am going to lengthen the bedsides to match the cab and shave the gas doors, the seams on the bedsides, and reshape the bed rails to match the lines of the cab. The front suspension will be an 89 2wd front clip modified to meet my needs with tubular control arms.
  8. '80yota
    '80yota Enthusiast
    Spokane, WA
    '80 Sr5 Long bed
    sick!
  9. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    She got put on hold for a little bit. Had to link and bag an ice cream truck for a local guy and put a new compressor on a scion. Started to build my tubular arms today. Here are a couple of pics of the progress on those.
    Notching the tubing on the mill....
    Parts notched waiting to be welded.....
  10. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    rite on, sick asss project. love the stouts! cant wait to see more pics...keepm coming!!:applause:
  11. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    I have all of the arm parts notched and sanded. Just need to weld them up. If everything goes well I will be starting on the front clip this weekend.
    The upper arms
    Both the uppers and lowers
  12. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    Got my arms welded up today. I started on the front clip and hope to have the bag mounts, arms, and steering linkage on this weekend.
    assembled
    just welded
  13. Dgerfan55
    lake elsinore CA
    94 pickup
    Man thats nice work. Well done bro
  14. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Where did you get the cross shafts for the arms?
  15. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    How much would you charge for a set of those?
  16. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    Damn nice work...
  17. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    Thanks for the comments. A set of arms like these will run about $750 plus shipping.
  18. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I just noticed these r cando arms. I'm guessing you work for them?
  19. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    Yes they are cando arms. I do all the machining and fabrication and steve does the tig welding and shipping.
  20. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    Imessed around with the front clip a little bit. I shaved some holes, cut off the motor mounts, and welded in the lower x shafts. I also started cutting up the shock towers to make room for the bags.
