dropping the front???
Discussion in 'Suspension/Chassis' started by jdr492, Jan 14, 2013.
  1. jdr492
    jdr492 Member
    spring, tx
    It's time to start ordering parts..... after doing a lot of reading i just need to ask two questions... between cutting springs, belltech mighty max springs, and the moog springs which has the better ride?? which one provides the better handling? if i cut i was gonna cut 1 coil and do the ball joint flip. if i've read correctly should get me around 3"???
  2. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    Idk about the mighty max or moog springs but I do know that cutting coils may/is bad and makes them weak but belltech is a good aftermarket drop kit choice also heard moog is a pretty decent brand but like I said HEARD someone correct me if I am wrong anyways good luck on your drop :waytogo:
  3. jdr492
    jdr492 Member
    spring, tx
    Anyone have the part number for qa1 coilovers?
