drop spindles bell tech
Discussion in 'Suspension/Chassis' started by craigdbl, Jul 16, 2011.
  1. craigdbl
    craigdbl Guest
    I'm installing my spindles today.I got to reinstalling the drop spindle but,when I was tightening the upper ball joint the bolt with the taper kept spinning.Should I hit the spindle in an upward motion to seat the spindle on to the taper? thanks
  2. bigc9093
    bigc9093 Member
    Macon, Ga
    80 daily, 86 x-cab hauler, 90 2wd, 93 bagged
    If you can get a pry bar in there to pull down on the upper control arm to hold tension on it then start tightening the nut that should seat the balljoint shaft and stop it from spinning
  3. jetas
    Find a way to put pressure against the BJ so it doesnt spin. You could probably raise the whole assembly. So the BJ moves in the cup and most likely will stop spinning.
  4. craigdbl
    craigdbl Guest
    ok,thanks I'll give it a shot.Getting some of those nuts loose did a number on my back I'll see how motivated I feel tomorrow.
  5. jetas
    Did u use a cheater bar?
  6. craigdbl
    craigdbl Guest
    yes,them puppies where on there good.
  7. jetas
    The ones on the BJs? They shouldnt be on there tight at all.
  8. craigdbl
    craigdbl Guest
    yea,those where easy-most of the other ones were tough.
  9. jetas
    True. I remember i was guna do a BJ flip on my old truck but the bolts holding the radius rod sh!ts just wouldnt budge.
  10. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Use an Impact and jounce it to get it to seat. Should be no big deal.
  11. craigdbl
    craigdbl Guest
    I put a 2x4 on top of the bj and up to the fender well and jacked it up and that did the trick.I made some progress today but,the belltech 2000 kit was missing a couple of 12mm bolts to hold the dust cover on and I haven't had a chance to get them. I'll have to call Belltech to update that kit,it's slightly different than the stock one.
  12. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    They are always missing those 2 bolts....I had to get them from Toyota (dealer). You also have to trim the plate behind the brake rotor to get it to fit.
  13. craigdbl
    craigdbl Guest
    I got my drop spindles and shocks put on and running.I like the ride,I don't have to be over cautious of bumps.I can go over railroad tracks @ a good speed as well as cement water gutters in the street.I'm 3" in the front and rear.
