I need to take apart the fuse box in engine compartment. When I removed my damaged front clip I cut it away around the wiring harness. Now ready to remove the replacement clip but need to remove this harness. I see that a couple of the wire sets, go to the top and unplug, the rest are underneath, a couple are held in with copper screws. But the rest, do they just pull (with force) out? If not how can I remove them?
Some of the fusible links in the fusebox are screwed in. U needa unscrew em from the bottom of the box
