disable door buzzer
Discussion in 'Interior/Electronics' started by OGtoy, Nov 16, 2008.
  1. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    i was wondering if anyone knew how to disable the door buzzer when the driver side is open and key is in the ignition.
    right now i disconnected the wire switch but i want to be able to use my light.
    let me know how i can do this! thanks.
  2. IronNam
    disable buzzer only, not wire
  3. tehsk
    tehsk Enthusiast
    Northridge, CA
    88 2.4L Carb
    My truck had a spring wrapped around the little sensor. I pulled it off and it turned the door buzzer off.
  4. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    yaa that doesnt help at all.....
  5. IronNam
    yeah cuz i have never done it =/
    i wanna find out too lolol
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    track down the buzzer
    pop the cover off, look for teh lil speaker thing
    disable it with small dykes or a knife or sumthin
    pop the cover back on.
    you might have 2 different buzzers, one for the key and one for the seatbelt, some older yotas have 2
  7. IronNam
    i wanted to keep one for lights.. ill make a flip switch
  8. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I wish mine would learn to stfu and go die, its a pain in the ass when you are tinkering with your motor, starting it and shuting it off over and over again
  9. chamaraa73
    chamaraa73 Newbie
    Sri Lanka
    92 Toyota Hilux double cab
    door buzzer -key reminder
    mine is a 91 double cab with 3L diesel,
    i traced the key sensor wire from the ignition switch (a black/white on the top left corner on the connector) that send the signal and cut that off.
    no annoying buzzer with key in and door open,all others are working (dome light , key light..)
    but the ligts on reminder works
    chamara
  10. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I just took it completely out haha
