Conceled Kill Switch
Discussion in 'Maintenance/Repair' started by NavyMC, Jul 2, 2012.
  1. NavyMC
    NavyMC Member
    TN
    78 SR5
    I am curious how you would wire a kill switch on a 78??? TRfknD, any thoughts? I have the switch in my cab already, although not conceled... I am not totally profecient when it comes the the PFM of electricity's switchology, though I get it from a physics perspective. Any ideas or pics/explanation of others' set up would be greatly appreciated... :shrug:
    I totally feel for the dude that got his ride stolen and I would be crushed if someone took my little yellow truck!
    Cheers!
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    In my old civic I had a push button ( hold down ) while you turn the key hidden under the dash were only a finger could find it or fit . It was wired to the starter signal switch more less like a incomplete circuit until you held the button down fairly simple to install/ wire up don't no if this would work on a yota if u break a Honda ignition a flat head will crank it as well as unlock the steering . I'd purchase a nice alarm and do a kill switch .
  3. Inertia
    Inertia Enthusiast
  4. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    The way I had mine was I cut one of the wires that go to the ignition switch and that cut all the power from the truck. The way I did this was with a test light just touched the wires and got the one that had constant power and it worked great . If you want pictures LMK
