Common Rust Area? Battery Tray
Discussion in 'Exterior/Body' started by KS.ID, Jun 25, 2018.
  1. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    Hi All! Going through this late 1972 Hilux and I've discovered the rot beneath the battery tray. Any tips for restoring this area? Common area for rust?
    I know I'll have to cut it out and re weld a panel. I've also drawn up some CAD for a new tray.
    Here's the rest of the engine bay
    Thanks!
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Pro-15 is the best product out there to treat rust .:cool:
  3. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    Thanks! I've definitely heard of Por-15. It is still advised to cut and replace as much as possible?
  4. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Pretty common rust area for most vehicles, simply a downfall to battery acid leaking on metal.
    PO did a half-assed repair on my truck, which I plan on correcting someday. I'm just going to buy a battery tray, at $10-30 from Summit it's cheaper than my time to fabricate one.
  5. Clay
    Clay Member
    Ohio
    93 Pickup
    If you use por-15 you have to do the metal prep. either their metal prep or one from eastwood. It's an acid/zinc process that's critical to long term repair. replacing that part is still the best, but at least you can treat the surrounding area with a rust paint.
    KS.ID likes this.
  6. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    That's a good option. Does Summit carry something that is specific to the toyota pick up?
  7. Perkolator
    Placer County
    1975 Hilux
    I dunno, likely not these older models.
    It’s just a simple shelf that you can weld, bolt, rivet, etc to your engine compartment.
    Different styles too - like traditional shallow tray with the hold down strap mechanism, to something like the trail gear “box” that’s more of a full cradle for vehicles going off-camber
