Cold air intake idea
Discussion in 'Engine/Drivetrain' started by Coldmonster, May 7, 2014.
  1. Coldmonster
    Coldmonster Member
    So I know most CAI will pull hot air from the engine compartment while factory boxes will actually draw in cold air. But I was thinking of doing the battery/intake swap then cutting the filter into the fender like ford did on my f150. I know that area is very small but I have access to tools to modify the area to make it work. It is also enclosed from most water spray so that shouldn't be a problem. Only problem I see is how hard it would be to change the filter. Has anybody tried this or have any thoughts or comments on it?
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I did this ,draw cold air from two feeds from outside the engine bay.
    Drilled a 5'' hole at the side for a feed from the wheel well, & a 3'' hole at the bottom,feeds from behind the front bumper.
    I use a reverse cone K&N filter & made a box with removable top from aluminum.:cool:
  3. Coldmonster
    Coldmonster Member
    That's pretty much what I had in my mind. Do you have any pictures of it completed.
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    The air filter front,the tapered end ,sticks out of the hole a few inches & I have a slash guard on the rear ward sidefor water off the tire.
    I'll get a photo of that!:cool:
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Here's the view from under the fender,the splash guard is 1/3 round,open @ the front.
      File size:
      38.4 KB
      69
      File size:
      58.4 KB
      73
  6. Coldmonster
    Coldmonster Member
    That engine is clean. But that is just what I was thinking. Did you notice any more throttle response/gas mileage. Also do you pass smog?
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Thanks, & yes it goes though smog test with no problems.
    This is no a stock engine ,it's a LC stage 1 Pro Street EFI !
    Lots of power & gas mileage is 26-28 with driving 70 & above,if I cruise @ 65 she'll get 31.:cool:
