i just changed out my master cylinder for my clutch because i was losing pressure. now 2 weeks later its happening again. it dosent look like its leaking again, its brand new, so what else could i do? thanks
yea i did. as far as i can tell its not leaking. i might just change it to be sure. is it possible to have issues with the master only 2 weeks later?
well...i guess you could, but its usually if someone bend the pedal or something like that and the rod is going in crooked to the master, or maybe you got a defective master. i donno, check for leaks is all i can say from here, and if in doubt replace the master again and the slave. whats the problem you are having? clutch pedal sux and you have to pump it up to finally get a pedal?
I read on here one guy had the bracket that holds it in place in the cab rusted apart. check underneath the dash that the supports aren't flexing when you push it down.
