clutch cancel switch installed
Discussion in 'Interior/Electronics' started by Da_Roach, Sep 30, 2014.
  1. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Big thanks to whiteDLX210 first
    I removed my lower dash panel under the steering wheel and I found the plug for the switch. Was taped to the speaker wire. Removed the blank and installed. So I I know it not a big mod or really important but damn its nice I think. I know I broke the rule of photos but as usual I did it w/o a camera.
  2. Suprafreak13
    Suprafreak13 Member
    Sweet I was wondering and hoping it was possible, and that easy.
  3. maxpowers95
    maxpowers95 Member
    BayArea (510)
    93 ext.cab 2wd
    Did the same to mine, took the dash off to change clusters and I saw the taped connections, so I went to pick n pull, and was lucky enough to find a switch. I was also prewired for the tachometer, which was a plus.
  4. 93TILinfinity
    93TILinfinity Veteran
    Lake Elsinore, CA
    1993 Toyota pickup 2wd 4cyl 5speed cab and a half standard bed
    Can the switch be off of 4runners or just sr5 pickup?
  5. Da_Roach
    NOVA
    Doesnt matter. Im using one removed from a tacoma. I have a tool box drawer full of toyota switches that I find in my travels.
  6. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    Hell ya could use a toggle switch or just hard wire it to be live all the time
  7. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    What does this do exactly?
  8. NashMan
    NashMan Toyotaholic
    94 2wd
    Safty switch for the clutch can be over ridden
  9. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    so you can start the truck without having to push the clutch in....
  10. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Ahh, I see. That is a fascinating option.
  11. 93TILinfinity
    Lake Elsinore, CA
    All the plugs are the same? Just want to be sure when i grab one
  12. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Not really I've bypassed the switch on every rig I've ever had that came equipped with it. :lol:
  13. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Find the smallest toggle/flat switch you can find and hide it as an anti-theft device... Just dont forget where you hid it... :eek:
  14. 93TILinfinity
    Lake Elsinore, CA
    I use to have a kill switch but it got on my neverves. It was on my ac setting and you had to have it on the right setting for it to start
  15. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    It was fascinating to me as I've never really thought of having the need for bypassing it.
  16. White Trash
    Eastern WA
    It's a 4x4 thing. If you kill the truck on a hill it allows you to push the cancel button so you can start the rig in gear so you don't have to side step or slip the hell out of the clutch and risk sliding down the hill.
  17. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Yeah I never got caught up in the 4x4 thing. My father on the other hand is big into it, but he uses his monster 4x4 1942 Jeep Willys for that.
  18. whiteDLX210
    whiteDLX210 Newbie
    San Antonio
    94 DLX Xcab
    Thanks for the props! :waytogo: I use it every time I start the truck, I know it's not necessary but whatever, it's convenient. :headbang:
  19. White Trash
    Eastern WA
    I don't push my clutch pedal in or push a button every time I start my truck. Now that is convenient. :nana:
  20. whiteDLX210
    whiteDLX210 Newbie
    San Antonio
    94 DLX Xcab
    mine is factory fresh without having to cut and splice wires so you don't have to track down electrical problems later down the road if anything ever happens :nana:
