cleaning intake manifold
Discussion in 'Engine/Drivetrain' started by Kristian43, Nov 15, 2010.
  1. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Ok so this week imma be cleaning my intake mani and tb im going to remove it and clean it by hand with lotsa elbow grease so i need some recommendations as to what i should clean it with
    imma get a can of tb cleaner but besides that what should i use to get all that buildup outta my 22re intake mani?
    also any info on what i should do while i have it off
    p.s. im only removing the tb and upper intake mani.
    gracias!
  2. IronNam
    should be easy man. I think one or two cans of carb/tb/intake cleaner will do you good. even if you want, go ahead and get the cheap stuff in a bigass can. more stuff for price right? same ****, have fun.
  3. garagedoorman
    garagedoorman Addict
    north georgia
    The intake plenum should be pretty clean. You should only have a little gunk build up on butterfly. If it real dirty you need better filter
  4. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Nope i gotta good filter. Its not super funky but the gunkiest mani i've seen so far. I think it may have something to do with the pcv releasing into the upper intake mani.
    Also i saw they have this can of engine degreaser will that work ok for the inside of the manifold?
  5. garagedoorman
    north georgia
    just rinse it all, and dry
  6. Kay_XRS
    Kay_XRS Newbie
    Pomona, CA
    Its not really dirty because of the filter, its usually just the vapor of the oil from the vacuum hose that leads from the head to the intake, thats why its all greasy
  7. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    You should do a intake swap. Swap it out to the straighter style one.
  8. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    If you want it REALLY clean, take it to a auto machine shop.
    They have a parts cleaner that will make it look mint. And its cheap, and easy, and because cleaning by hand sucks. :lol:
  9. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Well im trying to do this the cheap way and i seem to have more time than money on my hands :/
  10. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    easy-off oven cleaner cleans the crud and nastiness out of old carb bowls great, should work great on manifold carbon. make sure you have lots of ventilation, wear gloves, and don't let it sit on the AL too long or it'll start to oxidize and turn dark.
  11. IronNam
    it's the EGR that makes it dirty most of the time. I haven't looked in my intake manifold in a long time. I haven't had EGR connected in forever.
  12. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    PCV can contribute a bunch too depending on the condition of the engine. I'm curious about my cressida too... ditched EGR at the rebuild and put in a catch can.
