Change in idle are warm up
Discussion in 'Engine/Drivetrain' started by 1988toyota4x4, Feb 15, 2011.
  1. 1988toyota4x4
    1988toyota4x4 Newbie
    I just got an 1988 Toyota pickup 4x4 22re efi, while just sitting there the truck idles good with no problem, i drove it around the block for the first time today and after it warmed up when i would let it idle i noticed the idle would drop down then come back, drop down and come back up untill i would press the gas again then it would stop. any ideas why?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    vacuume leak probably...start searching for cracked rubber lines.
  3. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Its probably the cold air idle valve. Id start with adjusting the idle control valve to lower your elms a bit and if that doesn't help clean out your throttle body and replace the cold air idle valve.
  4. 1988toyota4x4
    Got it fixed
    Thanks for the info it was a valve leak i found it right on the fuel injection manifold.
    Dwayne
