Cautionary Tale of 20r Aisan Carb
Discussion in '1976-1983 Build-Up/Project Threads' started by Davo, Jul 26, 2020.
  1. Davo
    Davo Newbie
    How many times have you read a thread where someone reported rough, high idle and, usually, gas dripping from the booster? Help! My mixture screw does nothing! Yup. That was me. I searched many a forum because this was the problem I had with my rebuilt 1978 pickup's 20r. New stock carb, vacuum hoses right, rebuilt head, all stock emissions...I tried everything. Well, almost. After 2 months of reading and learning, 5 repair manuals and the FSM, I determined that my idle circuit was not operating. I will end the suspense. Wasn't a vacuum leak or a clogged port. It was...drum roll, please...the electric idle stop solenoid. I read in one place that since my year wasn't equipped with a plug for this, just ignore it. I finally figured out that it plugs up the idle circuit...Aisan apparently underestimated our ability to fiddle with the carbs various screws until it would run and sort of idle even with the circuit blocked. Needless to say, once I applied power and ground to this solenoid, the mixture screw magically started working. My truck now idles perfectly and quietly at 900 rpm. Well, if you understand this post, feel free to add your story or elaborate further on anything I missed.
  2. Davo
    Davo Newbie
  3. fred heath
    fred heath Addict
    Raleigh, NC
    Aisan carbs are a PITA. So many things that can go wrong. I switched to a Weber 32/36 and couldn’t be happier.
    Glad it worked out for you.
  4. Cocolux
    Cocolux Newbie
    I'm having a similar problem, looking at a Weber right now. Thanks for alerting me through your own findings.
  5. Davo
    Davo Newbie
    I actually got the truck to pass California Smog! Everything stock. Passed with like new number, the tech said.
  6. Cocolux
    Cocolux Newbie
    Geez, that's pretty cool. My coco is stinking of fuel at the moment. I have a rebuild kit but not sure if I should waste the time. Did you rebuild yours Davo? Cheers. Ben
  7. Davo
    Davo Newbie
    DavoNewbie
    I did. Make sure the fast idle screw is not in too far. If you see any gas coming from the booster, it is not adjusted right. The flap butterfly thing, I forget the right names, should not allow enough suction during idle to activate those. All the gas and air should come from underneath it where the idle circuit ports are
    Cocolux likes this.
  8. Yusuf RN20
    Yusuf RN20 Newbie
    Hi there. I am new to this forum. I think i may have a similar issue. Do you have pics of the wire and how you fixed it.
  9. Davo
    Davo Newbie
    Hey there, Yusuf. I will get some pics today. I have to adjust my valve lash, anyway. Stand by for later.
  10. Cocolux
    Cocolux Newbie
    Sweet! Cheers Davo, may try to take a look at this on the weekend and evaluate it more closely. I picked up an original manual the other day which has the carb rebuild outlined. My kit does not have one of the diaphragms included though so hoping whichever one it is , that it is in good condition.
  11. Dave Ayars
    Dave Ayars Newbie
