Carbureted 22r to efi?
Discussion in 'Engine/Drivetrain' started by kenichols29, Jan 8, 2012.
  1. kenichols29
    kenichols29 Member
    I want to convert my pickup to efi. What parts are needed? I know you need a EFI manifold and an ECU but is there a wiring harness needed? And what Kind of work would be involved in doing this? Thanks.
  2. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    There is actually alot involed with it, thats if your just doing stock setup. Best to get a donor truck to pull everything you would need. If anything check Lc Engineering.
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Efi
    Wire harness,computer box,efi dizzy,in tank fuel pump. Kind of a complicated swap but not impossible.
  4. kenichols29
    kenichols29 Member
    Well im reviving this old thread because I have a truck with efi that im gonna use to convert mine. Any one who has done this swap before can you give me a few pointers?
  5. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    swap gas tanks. and just about everything thing else !
  6. oldschool64bus
    oldschool64bus Veteran
    Boise, Idaho
    1983 SR5 4x4
