carb tuning
Discussion in 'Engine/Drivetrain' started by Comrade_Charlie, Apr 26, 2010.
  1. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    Can you tune a carb so lean that it will hurt the engine? or will it just not run? Im going to try to tune my carb but im scared about hurting the engine....
    ive hear lean it out till it idles up, turn idle down, lean it out till idles up, idle it down, then when it quits idling up from leaning it out its good...? I dont know.
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    ya you can be in the lean range and it will run hotter, misfire, and lack power. you want to be on the richer side with a carb, it will run smoother, idle colder and have a little bit more umph to the truck. I completly turn the idle screw all the way out, so its not effecting idle speed, then turn the fuel screw all the way in which is full lean, it should run like serious poo at that point. then slowly start unscrewing the mixture screw until it idles smooth. note that point, then keep going until it idles like crap again.. pick a place somewhere inbetween the rich idleing like poo and the super smooth place, then up the idle with the idle screw if needed.
  3. Nook
    Nook Addict
    oregon
    The idle mixture screw is just that, idle mixture, it really does nothing other than control idle quality, you can lean it or richen it, but normally you adjust it to the best idle quality and highest manifold vacuum, once the throttle plates are cracked open the idle mixture is just along for the ride and have nothing to do with how rich or lean the engine is running, that is controlled mainly by the idle jets and the main jets, plus other things like emmulsion tubes, air correctors and so on. Your better off to adjust for best idle quality then start doing some plug reading after some hard pulls to see how the color is to dial in the jetting richer or leaner.
  4. Comrade_Charlie
    1973 Hilux
    If thats so I shouldnt need to adjust anything because its the stock carb for the engine?
    I miss fuel injectors.
  5. Nook
    Nook Addict
    oregon
  6. Comrade_Charlie
    1973 Hilux
    haha thats the only choice I have really. I think my ign timing is causing my power problems.
  7. dillinja666
    gotta start with the basics. messing with the carb with jacked up timing is a waste of time. you have to get your base timing set first before you tune your carb.
  8. Comrade_Charlie
    1973 Hilux
    I think thats what my issue was, ign timing, I have it set at 7-10 degrees and it has pretty good power now.
    but, when driving, it just starts revving up on its own and wont quit till you cut the engine off and turn it back on. Ill have to check all the hoses
  9. Nook
    Nook Addict
    oregon
    Oh No :eek: not another unintended acceleration model to add to the recall.
    :ROFL:
  10. dillinja666
    lol!
    check your idle scew and mixture screws. I had mine set so rich that it would do that. If you touched the throttle it would just keep accelerating. I spent a good deal of time messing with my adjustments until I got the idle and fuel ratio where I liked it.
  11. toy_boy
    toy_boy Addict
    California
    1979 Toyota 4x4
    Check your linkage.
  12. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Try spraying the carb in and out, linkage, and down the speedo cable with carb clean.
  13. Comrade_Charlie
    1973 Hilux
    Id like to check it when the problem is happening but the engine races so much im scared it will get hurt... the bracket that holds the linkage to the firewall isnt so hot, but who knows... Ill try to figure it out.
    And lol me and my friends wanted to roll up to toyota and be like "recall"
  14. dillinja666
    do it...make sure you get it on vid though, would make a great youtube vid
  15. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    OMG BAD MEMORIES BRO!!! i remember when that had happened when my pops was driving the yota, that thing in the middle of the FWY reved up all the way up on it's own!! i was shting bricks!!!! lmfao!! i was like 11 idk wtf was going on!!.... but we moved to the shoulder and he left it on, he moved something then it got normalized....
  16. Comrade_Charlie
    1973 Hilux
    Theres something I back out, sorta like the idle adjustment and it fixed it, dont know what it is but ill take a picture, seemed to fix it, I did a test driving dogging the crap out of it and it didnt do it.
  17. dillinja666
    probably the mixture adjustment....
  18. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    weber time dude. stock carbs are poopy. :D
  19. dillinja666
    very much so...craigslist em..you can find them for the cheapz...
    beer. yes
  20. Comrade_Charlie
    1973 Hilux
    I have to wait till I sell this 4x4 85 or 86 toyota truck I bought... I dont have a job I just buy and sell stuff.
