carb to efi?
Discussion in 'Engine/Drivetrain' started by Johnno919, Aug 31, 2014.
  1. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    i got a 22r carb engine and i was wondering how hard it is to efi swap,
    i can buy i second hand set that come with the following,
    .ecu
    Inlet menfold
    Main ecu loom
    Air flow meater
    Efi fuel pump an reg
    Fuse box .an most of wats needrd to get running.
    would it be beneficial to swap or just stay with carb and maybe upgrade to a webber carby or something.
    i will be grateful for any help :waytogo:
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    89-95 is easily the easiest generation to swap to efi due to the simple modular design of the wiring harness. That said, I love my weber and unless the factory computer is changed a carb has more potential to make power.
  3. Johnno919
    Johnno919 Member
    Australia
    22r 91 Xcab
    ok cheers for the imput the efi kit is $200 and not sure where to get a weber in aus, im more leaning towards a weber tho if i can find one,
  4. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    89 2WD reg cab, 85 4Runner
    Did you decide to move forward with your EFI swap? I am currently doing a carb to EFI swap on my 89 pickup. You will either need to get a main body harness as well, or spend lots of time soldering new wires and making splices into the existing harness.
