Camber
Discussion in 'Suspension/Chassis' started by ToxicToyz, Mar 27, 2011.
  1. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Any ideas of why the passenger side of my truck cambers more than the driver side. Both the torsions on both sides are lossend the same amount as each other
  2. thundering02
    thundering02 Addict
    Fenton 63026
    Even though they may be the same loosened are they the same height(side vs side)? Otherwise bad bushings or frame/control arm/hub damage may be part of it.
  3. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    They are the same height on both sides. So it could be the bushings or wheel bearings
  4. tuckintaco93
    tuckintaco93 Member
    holt , fl
    1993 taco
    mine dose the same thing ...the driver side has no camber at full lock but the driver side has meg camber ...the same layed out the pass side has more then the drivers side
  5. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    bad control arm bushings, wheel bearings, ball joints, or camber shims may have fallen out. check all those areas.
  6. tuckintaco93
    tuckintaco93 Member
    holt , fl
    1993 taco
    i have no shims in either side and all new ball joints and bearings arm fine
  7. SD YOTA
    less (or no) shims will cause more positive camber. more shims will cause negative camber. depending on your wheel and tire size, drop, and other suspension component conditions, your camber conditions may be amplified.
