camaro front shocks
Discussion in 'Suspension/Chassis' started by DisAsterPiece, Dec 26, 2013.
  1. DisAsterPiece
    DisAsterPiece Enthusiast
    potosi, mo
    89 reg cab 2wd
    I know, I know. There is crap load of threads regarding this. But not one answers the question i have. The lower mounting tabs on the camaro shocks are about a 1/4" off on both sides. I have read guys just using washers to mount them. That don't seem safe at all to me, so question is this. Can you take out the mounting tabs from original shock and slide into the new camaro shock? That way the bolt holes line up perfectly and its safe.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Use 3/8" machine washers and bolt them in. No need to think too hard about a non issue. Besides getting the cross bars out of the shocks will seriously suck even with a press.
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    to answer your question, yes. you can use your toyota type tab and replace the chevy ones.
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I always run a longer bolt to hold my shocks in, then use a nut and washer on top of the arm threads. And big washers down below too. I've had cheapies spread the split finger bolt "hole" and shove the shock out the bottom. No problems since the new hardware method.
  5. rvanderah
    rvanderah Newbie
    hey standardbyker can you post pics of your setup?
