Bumper Blinkers As Running Lights?
Discussion in 'Exterior/Body' started by LilRed93, Aug 3, 2014.
  1. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    So how do I make my bumper turn signals come on as running lights as well? Do I need to switch out the socket to the 1157 type?
  2. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Yes, then just tap the extra wire into the running lights wire.
  3. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Awww yes that's what I was thinking but wasn't too sure. Thanks.:waytogo:
  4. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    You can also play with the ground wires. If you cut the blinker ground wire off and splice in the power wire from the marker in it's place they will both be markers but when the lights are on and you use the blinker the bumper light will turn off when the rear blinker bulb comes on.
  5. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Or if your really ambitious you can add another small light to your corner lights and with a relay you can have alternating signals. :silly:
  6. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Seams a lot easier to just wire in a new socket. I found a set on ebay for 7 bucks. Thanks for the help guys.:waytogo:
  7. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    So Im Thinkin about doin the blinker to fog light swap! Whats the best led bulb to use?
  8. jetas
    LED bulb as a foglight aint going to be bright enough
  9. yotaman95
    1995 single cab
    They make a few pretty bright sets of Led but what do you suggest?
  10. yotaman95
    1995 single cab
    what do you suggest using?!
  11. Thomas johnson
    Thomas johnson Member
    Roswell NM
    1990 Toyota pickup
    They have a 3 wire bumper light I plan on going that route with switchback LEDs
    Erwin Merida likes this.
