Brakes acting funny.
Discussion in 'Suspension/Chassis' started by Xs5875, Mar 29, 2013.
  1. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Alright if you have been following my build you know I am bagging and body dropping my 93. With the body drop and the 18s the stock booster hit the tire laid out so to fix it, I re drilled the mounting holes and moved the booster over 3/4".
    Then it hit the steering shaft! So I took it out and used a hammer to roll one edge in slightly. Not like beat it in just indented it. So fast fwd to today and the test drive finally happens! But when I go to get in it and go, it won't budge. Brake pedal hard! Turn truck off, step on pedal a few times and it releases. Take off down road, come to stop sign, let off brake pedal and it keeps stopping by itself! And won't budge! Gotta turn truck off press pedal a few times to release it then go again. Wtf.
  2. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    ....shaft misaligned and binding?
  3. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    How hard did ya hit lol The power booster is a precision machine the rubber seal around the inside perimeter ..and a inner seal for the master cylinder push rod and a few vacuum chamber baffles . U said the pedal hard to push and sticking that's a sign of booster failure .. How's the condition of your rear brake cylinders and pads if there worn out bad they can over extended and not release . Is there a idle rpm change when stepping on the pedal
  4. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    ... i dont think it sounds like a vacuum leak, or an idle up issue.... sounds like, gonna need more monieeeez! lol :runaway:
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    No change in engine rpm when I press pedal. It bled out fine, all new brake pads rotors, shoes, everything. I did read about the pedal linkage needing adjusted, I moved the pedal assembly over 3/4" too, do it can't be too bad.
    How easy does a geo metro booster bolt up , as I hear that's usually the course of action when the booster hits tires.
  6. Xs5875
    Xs5875 Addict
    Greenville, Ga
    And once you release it, pedal isn't hard works normal! Just on occasion it sticks ..
  7. Litneon
    Cocoa, FL
    94 xtra cab
    Do you have any pics? If you've torqued it a bit with either the install or hammering, it can bind.
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Yea u could have just a binding issue on the rod .hopfully that's it and won't be to big of a problem
