Nice work there. What is the suspension setup and did you polish that intake by hand? Looks great and make that engine bay shine.
The front has two inch drop spindles, balljoint flip with spacers and re-indexed torsion bars. The back is 4in angled drop blocks with the overload leaf pulled as well as the one above it and the middle out of the three pack. Had to cut all bumpstops in half in the front and back. Had a crazy oil leak so had to redo valve cover gaskets. The manifold was done by hand using 30 grit to 300 grit dry sand paper... After that i did 300 grit wet sand to 2000 wet sand and then a polish wheel using red polish then white...the plenum wasnt that bad...the manifold sucked...before sanding i used an angle grinder on the plenum, thats why the toyota letters are gone...
