Ball joint question...
Discussion in 'Suspension/Chassis' started by ras0ne, Aug 29, 2011.
  1. ras0ne
    ras0ne Newbie
    Fort Walton Beach, Florida
    1991 Pickup 2WD
    First off I just want to say I'm new to this forum.
    I just bought a 91 pickup 2wd.
    I think the ball joint's need to be replaced. The truck came with new sets of upper and lowers.
    The question I have is...do you have to put grease in the ball joints?
    Looking at what I assume are the uppers, they have a nipple on the back end, I'm guessing your supposed to use a grease gun to put some grease in there.
    Thanks in advanced.
  2. jetas
    I dont think u can regrease them thru that zirk fitting
  3. IronNam
    I believe they are supposed to be?
  4. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Yes. Grease 'em. Through the zerk fitting.
  5. ras0ne
    ras0ne Newbie
    1991 Pickup 2WD
    How much grease do I squirt in there?
    Till full?
  6. jetas
    Swear someone had told me that you cant regrease thru that fitting. Maybe they were full of sh...?
  7. IronNam
    You should be able to fill it without making it burst. enough to fill it.
    and jetas, those zerks are there for grease filling... lol who said that?
  8. jetas
    An old friend told me that
  9. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    i think they were messing with ya
  10. jetas
    Lol. Na this dude was dead serious bro
  11. planemos
    planemos Toyotaholic
    British Columbia
    I have a full set of upper and lower arms from cando specialties. The lower ball joints that come with it have a zerk fitting or whatever its called. And you can put a grease gun on it and fill it. BUT the UPPER ball joint has this wierd fitting on it. It looks like a zerk fitting but it doesn't seem to have any opening on it. It is really wierd. I didn't put any grease in it. I believe they are a Chrysler ball joint? I was kinda wondering if I should shove some grease in there anyway or if it is pre greased? But ya that could have been what dude was talking 'bout.
  12. planemos
    British Columbia
    Actually that's not right. The upper ball joint that I have doesn't even have a fitting. It just has a hole on the ball joint where it looks like you can put a fitting in it. But you can't. Just a minor detail but I kinda thought all ball joints had to have a grease fitting.
  13. dillinja666
    some ball joints are non serviceable, they come with grease and when the boots pop it wont be long until the joint is done. Some are serviceable where you can grease em and even if the boots pop they will last a while longer. Having an open hole sux on your balljoint cause water gets in there and rusts the joint which kills em quick
  14. dillinja666
    so then why do they have grease guns for zirk (sp?) fittings lol he was messing with ya
  15. jetas
    Thats exactly what i thought
  16. ras0ne
    ras0ne Newbie
    1991 Pickup 2WD
    Cool.
    Thanks for the info.
    Looks like I'll be changing some ball joints this weekend. Doesn't look like its that hard.
