ball joint flip
Discussion in 'Suspension/Chassis' started by rylee k, Dec 2, 2013.
  1. rylee k
    rylee k Member
    hi state
    92 single cab
    Did anyone have problems getting their alignment into specs after doing this plus a little torsion? Any input will be greatly appreciated....thanks
  2. 89blaster89
    89blaster89 Enthusiast
    western wa
    93 singlecab
    i have the exact same question hopefully someone chimes in...
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    My 84 has 3" blocks with a bj flip & dropped torsions for a bit of rake. It has just a touch of negative camber but otherwise is almost perfect.
  4. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    Yep, flipped b/j and have djm lca's and shop wouldn't touch it cause they couldn't get it to spec. Even though one side was only out by 0.01 degree. Problem with "techs" nowadays. Find a good mechanic that knows modified suspensions. They will at least get it close or discuss it with you.
  5. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yea. flipping ball joints will get you some negative camber but, "within spec" is usually around 0.03*-1.05* of camber. most trucks once lowered will gain a couple degrees. i think im running somewhere around -3.5* on mine.
    the toe will be fine though. those dont take much to align. make sure to read into the torsion re-key article in the tech area.
