axle ratio 93 2wd???
Discussion in '1989-1995 Build-Up/Project Threads' started by white93turbotruck, May 28, 2010.
  1. white93turbotruck
    white93turbotruck Enthusiast
    i just read that my toyota pickup has a 3.58:1 rear axle on my 93 2wd pickup.i saw it on toyotareference.com.i saw it under the toyota pickup ad for that year.i thought i had factory 4.10:1 rear axle??? so does this mean i have long or short gears.i'm confused???:shrug::shrug::shrug:any help would be great thanks!!!!:D:D:D
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    To make this short and simple, post up a photo of the underhood tag. For your year, it should be on the firewall between the valve cover and the booster. Specifically, I need the bottom right corner section, but the whole thing is fine too.
    If you do in fact have 3.58s and you have the G code rear end, I have a spare 4.10 gear set I would trade you. Your freeway RPM would increase some, but your acceleration would be much greater for in town use. Even with 4.10s and 24" tall rear tires, I can get over 30mpg at 70-75mph. I just want the higher top speed of a taller gear. Basically, at say 5k rpm in 5th gear I am getting more rotations of the tire. Therefore, redlining 5th I'm not bound to about a 120ish max. :ROFL:
  3. white93turbotruck
    i'll show you my truck at the meet.that way you can see for yourself.that way you can see the truck for yourself!!!!
  4. standardbyker88
    lynnwood, wa
    Sure. But if you have 3.58s, I want em. :lol: 3.73s would be better but the 4.10s are too quick around town for me having the extra power. When it was stock, I loved them. Now I spin through the gear too quickly.
    On that engine tag, what does it say in the right corner at the bottom. Should say A/TM on the left with a set of 4 digits / 3 digits. Or they are the other way around. That will tell me what transmission and rear end you have, so I can make suggestions of what may work better for you.
  5. IronNam
    lmfao i would LOVE anything LOWER than my 3.73's right now.... I want my mpg's..... lol
  6. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Your gear ratio is located on the sticker on the doorjamb... Bottom right corner like sb88 said. Look for something like: A312 or G292 something along those lines with 3-digits preceeded by a letter.
    I have 3:42 and 3:30 gearsets in the 7.5" "F" code diff if anyone is interested...
  7. standardbyker88
    lynnwood, wa
    well, if you go too low then you just have to hold it up a gear and therefore save nothing. except maybe on the freeway. a 3.5/3.7 is right about where i want it. and if i dont like it, i can always change back. having the new motor and its power, i can push through the gears easier. almost too quickly...especially 1st.
  8. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
  9. IronNam
    lol a 4.10 or higher would let me go fast acceleration wise... low end, i suffer til about 25mph... that's where the truck actually wants to pickup speed lol.
    but a 3.30 gearset would let my truck LOVE the highway hahahaha
    i'd imagine that 1st gear would end at 60mph haahahahha
  10. standardbyker88
    lynnwood, wa
    1st wouldnt rev out that fast. I have done all the math, and for what I am doing, 3.73s are perfect. I have that PDF saved to my phone for junkyard reference :lol:
  11. IronNam
    lol 3.73's + automatic ends at 51mph @ rev limiter
  12. standardbyker88
    lynnwood, wa
    You know I don't care what the automatic does :ROFL:
    The automatic FAILS :ROFL:
  13. IronNam
    Pretty much.
    Since taller gearing would be nice mileage wise... that'd be neat. i'm getting like 21mpg lately
  14. standardbyker88
    lynnwood, wa
    Freeway or city? Mine gets that in city if I drive like SD :D Freeway, best tank was 31.5mpg. I haven't been clockin the new motor since I don't have a speedo hooked up. Not that it was accurate after the trans swap anyways. I will probably do the Sho mod and use one meant for a mountain bike :ROFL:
  15. IronNam
    it's been city lately. i havent used the highway much.
    but if i do, it kinda evens it out....
    I wonder how you got 31.5mpg with wittle tires and the gearing and way you drive :D
  16. standardbyker88
    lynnwood, wa
    because i kept the truck to about 60 for 250 miles. :ROFL:
    its still in the high 20s up to about 70-80. by 70 im turning 3300 rpm. 80, i dont know...but its too much for comfortable cruising.
  17. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    My BBQ grill slushbox has factory 3:73's... I think Imma drop in the 3:30's since I'm using smaller diameter tires...
    sb88~ Good luck finding 3:73's in "G" code @ the yard. 3:90's were more common in "G" code...
  18. IndianScout
    IndianScout Enthusiast
    1986 Yoda Truck
    most of my driving is open highway, love my 3.07's
  19. IronNam
    my gawd, i didn't know Toyota even made a 3.07!!!!
    I thought they stopped around 3.73's...
    Indian, is that the 7.5" F code you have?
  20. IndianScout
    1986 Yoda Truck
    number is..
    it's an 8" G662, indicating 3.07 gears and an 8" diff and 2 pinion open carrier
    tranny is a W46 4spd..
