Auto to manual trans swap
Discussion in 'Engine/Drivetrain' started by Adrian2013Ibarra, Jul 31, 2014.
  1. Adrian2013Ibarra
    Adrian2013Ibarra Enthusiast
    94 Toyota Pickup Ex Cab
    Can anybody point me in right direction of the full process of swapping an auto trans to a manual, its a 94 Toyota pickup 2wd, 4cyl, ext cab. The transmission is from a 86-ish celica-supra w58,I measured them and the w58 is about 3inch shorter, does anybody know a place around lemoore-visalia-fresno area that extends driveshafts? What is needed for the swap besides the trans itself, the master and slave, the pedal assembly and what about electrical wise? Did I miss anything? Any and all help is much appreciated, thanks
  2. Scomber
    Scomber Enthusiast
    Down East
    We may be on different coasts, but we're in the same boat. I did everything obvious to get the A43D working in my '92 DLX. Today I started ripping it out. I'm putting in a W55.
    I think you have most of it. You'll need to replace the torque converter with a flywheel, clutch, and pressure plate. Add those to your list. And don't forget the hydraulic lines between the master and slave cylinders.
    As far as electrical, I'll burn that bridge when I come to it. I know I'm going to need reverse lights and to defeat the starter lock. In a 5-speed, that's usually done with a clutch peddle switch.
    If Bangor has places that do drive shafts, then so does Fresno. I hear that most of the work is for agricultural machinery, but someone should be able to do it. I happen to have a spare drive shaft from the truck the W55 came from, so thats my extension stock.
  3. Adrian2013Ibarra
    Any news on the swap?
