I'm somewhat trying to sell my built 20r... For those who don't know I'll list off everything that's been done to it The bottom end has been: -hot tanked and magged -bored .020" -new pistons and rings -decked .010" for compression -reground crank with new main and rod bearings -new soft plugs -Engnbldr timing set (metal backed guides) -Engnbldr oil pump -new front cover The head has been: -surfaced .004" -ported, polished and gasket matched -22r valves (1.5mm bigger) milled in to work -sandblasted clean -RV2 cam -SBC valve springs (stronger and stiffer) -22r aluminum rocker arms Only things it needs to be finished are the front cover bolts ($30 from LCE, may buy and put on soon) and your oil pan and pickup tube. Only reason I'm thinking of selling is to fund a 22re build for my truck! If it doesn't sell by summer I'll put it in and use it. Asking $1200, that's less than a standard rebuild goes for around here. Open to reasonable offers. PM me if interested.
And it's sold!!!! Already started the next build not even an hour later... Probably getting custom made forged high compression pistons, fully balanced internals and professionally ported head.
