Aisan carb jets for 1977 20R Truck
Discussion in 'Engine/Drivetrain' started by zatoh, Nov 30, 2013.
  1. zatoh
    zatoh Newbie
    Does anybody know where to find both primary and secondary jets for an Aisan carb on my 1977 w/20R truck?
    I've been trying to get this truck to pass the CA smog test. I actually had it idling quite nicely but it still fails the CO test so I still need to lean it out. I've gone through everything - float level is fine, traced down vacuum leaks and verified vacuum connections.
    Looking through the access ports for the jets I see that they are pretty chewed up which leads me to believe that someone at some time attempted a re-jet. This also explains why I get such crappy mileage.
    I have heard that Weber jets fit but I am not sure what size to ask for.
  2. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    usually anything over 25 or 30 years old meets smog exemption.....
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Not in Cali. Anything 76-up has to pass emissions still. With factory parts or CARB approved parts
    As for the jets id say find somebody here who still has their stock carb from a weber swap and get small parts from them. I may still have a stock carb but I think they're all gone. Ill look around this weekend. Pm me a reminder if nobody else pops up.
  4. zatoh
    zatoh Newbie
    Thanks! Will do - I really appreciate it! Truck's been in the garage too long.
  5. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Are you sure it's not your catalytic converter that is bad?
  6. zatoh
    zatoh Newbie
    It's pretty new. I have probably less than 1K miles on it.
