Hey guys, I'm getting into air ride. I understand most of the concepts. I've bought a lot of parts already. The only things I don't quite understand yet are the specs on the air compressors. I need a compressor that I can mount below the bed (in the elements). I'm only running two bags in the rear right now (airlift dominator D2600 dual ports). I am going to run a 5 gallon tank with a 115/140 psi switch. I am running 3/8 valves and line. I want to be able to lift it every 10-15 minutes with no problems. I'm okay with running two compressors. I'd prefer to run a factory alternator. Can anyone make a recommendation? I was thinking of running Viair compressor(s) because they are such a well-established company, but I don't know what model to get. Thanks. -Nick
check out viairs site: http://www.viaircorp.com/OnRoad/compressors.html you can browse the different models, and they list fill rates and performance stats on each model.
Ya I'd go with viair. There very reliable an I had mine mounted under my bed on my Mazda then moved them to the bed an they were in rain an whatever else. Worked great I had the viair 450s now I have the 380s
Oasis are just really expensive my buddy had one on a full size an he got sick of it because it was so big an needed alot of battery power to start it up
