Aftermarket Oil Temp Gauge
Discussion in 'Interior/Electronics' started by Henry, Aug 31, 2020.
  1. Henry
    Henry Enthusiast
    Washington State
    Since I couldn't get the stock coolant temp sensor to work, I went ahead and installed an Autometer coolant temp sensor which has worked out great. This had me thinking I should also get a gauge to monitor oil temps in the engine. Does anyone run an aftermarket oil temp gauge? How are they normally installed on these engines? Sandwich plate on the oil filter?
  2. jetas
    Im running an oil pressure gauge and the sensor is on one of the of the oil passages On the filter side of the block by the starter
