Advice on what I should do bent part
Discussion in 'Suspension/Chassis' started by Minitrucker, Sep 28, 2024.
  1. Minitrucker
    Minitrucker Member
    Dang Jack slipped because of rough driveway and bent this part. Anyone know if I can just try to bend it back the best I can or if it needs to be replaced? If it needs to be replaced what’s the part name and is it available?
  2. RetirementToy
    RetirementToy Enthusiast
    Vallejo,CA
    1988 Toyota Extra Cab 2WD
    Looks like a sway bar. Take it off & with a press can be straightened !
    Minitrucker likes this.
  3. Minitrucker
    Minitrucker Member
    Thank you!!!
  4. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    1983 22R Long Bed 5-Speed
    Probs should replace it, might throw some alignment angles off
  5. Minitrucker
    Minitrucker Member
    Thank you for your input. It is not a moving part are you sure it will throw the alignment off? It’s just going to be a really hard part to find is the reason I ask.
  6. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    Oh the sway bar, my mistake. Thought it was the center link from the picture for some reason. Shouldn't do much if the sway bar is bent I'd assume!
  7. Minitrucker
    Minitrucker Member
    Fingers crossed because parts are getting extremely hard to find for this truck. I’m going to try and bend it back best I can. Thank you everyone for your support!
  8. redman
    redman Enthusiast
    Southcentral PA.
    Yea, looks to be the sway bar. Just remove and straighten, and I think it will be fine.
    83pickup likes this.
