ac bracket & pulley
Discussion in 'Maintenance/Repair' started by bigc9093, Apr 7, 2012.
  1. bigc9093
    bigc9093 Member
    Macon, Ga
    80 daily, 86 x-cab hauler, 90 2wd, 93 bagged
    can anyone post pics of ac compressor installed on their truck. I purchased everything to put a/c on my 80 but the compressor pulley does not line up with the others. wondering if the guy sold me parts from different year model or something
  2. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Here you go:
  3. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Here's a closer picture of the v-belts, compressor, & A/C bracket.
  4. bigc9093
    bigc9093 Member
    Macon, Ga
    mine bracket looks different. you can see where the pulleys dont line up. the tensioner pulley is pretty close but the compressor is way off:shrug:
  5. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Yup! That is way off. Is this an aftermarket A/C kit?
  6. bigc9093
    bigc9093 Member
    Macon, Ga
    no all from another toyota truck. just wondering what year or years it all came from!
  7. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    The RN#3, 4#, & LN40 does have a specific A/C bracket. When Toyota rolled out the RN50 series in 1984, then parts numbers and part designs also change even though it's still on a 22R motor. Either find a period correct A/C bracket or find an aftermarket one.
    Rick
  8. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Looks like the compressor and bracket are different era's as pointed out. The idler will line up if the correct spacer is used behind it. There are a couple different spacers that will fit. The power steering idler spacer is thicker and is likely what is on there currently.
  9. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    1983 Toyota SR54x4 Mojave Edition-Black Package Shortbed Sport Truck
    Do have the right Crank Pulley? The FED A/C systems and California A/ C systems are different. Different A/C Compressor mounting brackets, Idler Pulleys and Crank Pulleys. It looks like you have a Fed A/ C compressor bracket but I really can't tell by the photos. I think you need the three groove Crank Pulley even if you do not have power steering. By installing the 3 groove pulley everything should line up.
  10. bigc9093
    bigc9093 Member
    Macon, Ga
    thanks for all the info. i contacted the guy i got it from just waiting to hear back from him. i'll have to check into that 3 groove pulley. i know i have 3 or 4 harmonic balancers in my parts collection just not 100% on how many grooves they have
  11. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    I have a 1983 Toyota Truck Federal A/C System with Power Steering and my Crank Pulley is 3 Groove. All my pulleys line up. 1979-1983 Toyota trucks Federal A/C Systems all used the same parts and 1979-1983 Toyota trucks California A/C Systems used the same parts but again you can not mix parts between the Federal and California systems.
  12. bigc9093
    bigc9093 Member
    Macon, Ga
    well a month later finally got the correct parts to complete the ac setup. only question I have is where does the compressor plug under the hood? pic greatly appreciated
  13. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    Compressor plugs into a Brown wire located in the engine harness, right side fenderwell, near the battery. Should have the same type (single pole) and color connector as on the compressor.
  14. Francisco.a
    Francisco.a Newbie
  15. Markus Vandevender
    Markus Vandevender Member
    Auburn
    1978 Longbed
    You should post this in the 89-95 discussion forum, try not to hijack someones post please
  16. Jbird
    Jbird Newbie
    I have a 94 toy pick and have the some problem only one bolt holding in place in the front of it that where it broke where can i find one because my wife is the one driving it and she not going to with out ac so she driving my car so help need it fast to out her out of my car
  17. Jbird
    Jbird Newbie
    Did u ever find one or a replacement for it
