A/T floor shifter trans
Discussion in 'Engine/Drivetrain' started by TOY|STORY808, Jan 27, 2010.
  1. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    i noticed when my overdirve button is on or off it doesnt make a difference.......
    and how much speed it is.....????
    do you guys think that it needs to be rebuilt or just serviced??????????
    i
  2. TOY|STORY808
    1985 TOYOTA PICK UP
    anyone???
    no one???
  3. IronNam
    The only thing the overdrive button does is control the 4th gear function.
    Turn off overdrive and you'll have 3 gears.
    Turn it on and you'll have normal 4 gear operation.
    I have not seen any performance differences in turning off overdrive, especially from a stop.
  4. TOY|STORY808
    1985 TOYOTA PICK UP
    i know what the purpose of the over drive button... but
    it doesnt work at all so i only i have three gears....
    so i was asking what would be the problem to that
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    i would try replacing the switch if its not working. it could be that it isnt letting power through to let the trans know its in the default on position. try that and see how it goes. should be the quickest and cheapest thing to try.
  6. IronNam
    oh okay, i mustve misinterpreted what you meant. yeah, im thinking wiring.
  7. TOY|STORY808
    1985 TOYOTA PICK UP
    I checked whatever I could the switch works
    So I'm thinking its the over drive solenoid
  8. TOY|STORY808
    1985 TOYOTA PICK UP
    is it true that the overdrive wont work if the coolant temp is not giving a signal to the over drive relay???
    i need help finding where the over drive relay is at...
    the haynes manual doesnt chow anything like that??
  9. TOY|STORY808
    1985 TOYOTA PICK UP
    no one knows????????
