A little help please...
Discussion in 'Wheels/Tires' started by Under Construction '93, Jan 28, 2011.
  1. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I have 4 brand new crown vic police interceptor steelies. 17x7.5 with 70.5mm centerbore. Definately need hub rings... If my math is correct. I have 6.5 in backspacing. I figured my offset is 2.25in. Which translates to roughly +57mm. Anyone know if these are going to have rubbing issues? Im going to mock one up tomorrow but i have to have the tires dismounted first... I dont want to buy new tires if im going to have issues... Any help/insight is greatly appreciated. Thanks in advance.
  2. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    That amount of offset/backspace, it sounds like you would have issues. but its only a 7.5" wide so who knows. Have you mounted them on and turned the wheel to see?
  3. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Going to do that tomorrow. Have to get the tires that are on the rims now dismounted first... They have 235 55 17's on them right now...
  4. ShortyzKustomz
    ShortyzKustomz Enthusiast
    Central Va.
    94 Single Cab
    Really depends on what tire size you go with bro
  5. Motormouth759
    Motormouth759 Member
    you will have rubbing i5mm spacer on the front issues. I have some 16x7.5 et50mm and with a it barely clears the the a arms and the grease fitting for the balljoint
  6. IronNam
    isn't +57mm offset pretty high like FWD?
  7. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    There was a guy in Florida tht had those on his bagged 89-95 reg can. On my 300 steelies I have a 215/45/17
  8. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    I was gonna run 215 50 17 to keep the same diameter for speedometer and whatnot. Gonna testfit 'em today and figure it out...
  9. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    So I finally got around to test fitting these wheels on my truck. I have a few pics. Wondering what the general concensus is... On with the pics... Turned all the way right there are no issues but to the left just before the lock it hits the strut rod. I dont have any tires yet...Wanted opinions before i buy any...
  10. Litneon
    Cocoa, FL
    94 xtra cab
    How did you measure the backspacing?
    If your measurements are correct, you will need at least 25mm of spacer to clear them with tires, maybe more.
    I got my 7.5" 18's to clear with approx. an 18mm offset. So you may need to go with as much as a 35 or 40mm adapter. But, I also have the 4wd fenders. (Looks like you do too?)
  11. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Here is a pic... From mounting pad to inner flange... Exact measurement is 6.25' (i had tires on 'em b4)
