Drop blocks, pull the middle leafs and loosen the torsion bars. I think you can get about a 3/4 drop from just that. Maybe lower.
Ahhh i forgot the bj flip!! N thinking about it, u get about a 1"-2" drop from just pulling the middle leaves
Here is a write up on how to do a B/J flip http://www.toyotaminis.com/forum/suspension-chassis-40/how-do-ball-joint-flip-sd-yota-5272/
yup drop blocks are about 30- 50 bucks depending on where you get it from, and the rest just costs you some time!!
3 inch blocks I put the blocks on yesterday gonna do the torsion bars tommarrow. i was wondering if some one could post some pics of a 94 toyota torsion bar bolts so i kno what to losen would be helpfull
Looking good man, pull that middle leaf back there. I see if i can get the pic of the torsion bolts your looking for.
http://www.toyotaminis.com/forum/suspension-chassis-60/lowering-6436/ Search button is ur friend in this kind of situation
Any lowering in the front will induce negative camber. I did about 3-4" up front and I had ~1-2 degrees of negative camber. Get an alignment on it? they will remove the shims to correct it.
