93 lowering questions
Discussion in 'Suspension/Chassis' started by 87pickup, Feb 2, 2013.
  1. 87pickup
    87pickup Member
    ontario ca
    87 single cab short bed
    I have a 93 single cab and I'm gonna lower it when I get out of training . I was wondering how low can I get with my 17"s without rubbing and what not
  2. taki_lalu78
    taki_lalu78 Member
    you can do the quick and cheapest route is crank the torsion bars about 2-3 inches and 2-3 inch drop blocks for rear, as long as the offset it pretty decent on the wheels they will tuck and trun no problem, since the 89-94 fenders flare out much more than the others..
  3. 87pickup
    87pickup Member
    ontario ca
    I was thinking bout buying the 3" lower arms 2" drop spindles for the front and getting 3" bell tech springs and 2" drop blocks trying to get a 5" drop but idk if I'll run into problems with the rims being to big
  4. IronNam
    too big?
    Depends on their specifications and what tires you run.
    I'm fitting 18x10's.
  5. 87pickup
    87pickup Member
    ontario ca
    Idk what I'm running i just got the truck and im way way far from home to check but I know they are dodge ram rims I believe
  6. IronNam
    any pics?
    I'm sure the bolt pattern is completely different.
  7. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    Dodge ram wheels are 5x139.7. They wont fit. What you need are Dodge/Chrysler passenger car wheels.
  8. 87pickup
    87pickup Member
    ontario ca
    These are what the rims look like all I know is that there 17"s. Would I need a c notch as well?
  9. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    With 4" blocks, I had a hair over 1 1/2" of clearance. When I carried 5 cases of water, I was hitting at every dip. You should definitely get a notch at 5"
  10. 87pickup
    87pickup Member
    ontario ca
    Thanks a bunch
  11. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    If you go past 3"/3", you are going to rub. what 3" Lower arms are you talking about? I have 15" rims with stock size tires and at 4"/4", the front and the rear rubbed and at 3"/4" just the rear.
  12. 87pickup
    87pickup Member
    ontario ca
    I'm getting ready to get my parts for the 5/5 drop I got several questions
    1. Do I need to c notch the frame or can I get away with it
    2. What kind of shocks should I get for lowered trucks
    3. Will I rub with my 17"s or am I better off getting 4x4 fenders
  13. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    1. Yes, also notch the mid cross member that's underneath the back of the cab or you will be riding on your drive shaft.
    2. Drop shocks, Beltech or Doetsh
    3. Yes
